Why does my turn signal oonly work on one side?
Turn signal works normal on left side, but it blinks rapidly on right side and only the front light blinks.
Это хороший вопрос?
Это хороший вопрос?
Hi Dennis,
A rapidly blinking turn signal often means that the light bulb is about to burn out. Try replacing the bulbs and see if that fixes your problem. This video might help with the replacement: https://www.youtube.com/watch?v=c0Rk3kh2...
Good luck,
Paige
Был ли этот ответ полезен?
You need a new Turn Signal Switch, relatively cheap part
Bulb replacement solved the problem
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 121
1 Комментарий
Bulb replacement worked. Thank you
из Dennis Johnson
