Why wouldn’t my laptop power on?
My laptop is not powering on even after holding the power button. How do I power it on?
Это хороший вопрос?
Это хороший вопрос?
Make sure your battery is charged by starting your laptop with the charger plugged in. If that does not work, you can also try following our troubleshooting guide.
Был ли этот ответ полезен?
Will disconnecting the battery from the logic board and disconnecting the power supply cause a spontaneous reboot when the battery is plugged back in?
First i would check if it is plugged in, then also if the battery is charged. when you have both the adapter and the battery connected then you should be getting a charging light even if the laptop is off. The first thing i would question would be the power adapter and then go from there. good luck
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 130
1 Комментарий
student, iFixit Technical Writing Project
из L Pfaff
