Released in 2015. Identified by model number MJS T2702.
How do I access data saved on my SD card?
I can't access an app that I have saved on my SD card. How do I access the information?
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Выбранное решение
Sounds to me like you need to install a free file manager. If your on a android device i recommend that you install es file explorer from the Google play
Был ли этот ответ полезен?
Счет 1
There are several reasons why you may be experiencing this issue. First, your SD card may be locked. To fix this, remove the card and make sure that the lock switch is not pushed all the way down into the lock position. Second, your SD card may not be supported by the device. To fix this, you can either purchase a card with a smaller GB storage or upgrade the software on your tablet. Third, your SD card could be damaged. If this is the case, the card will not be recognized by the device, making your apps inaccessible.
Счет 1
Добавьте свой ответ
Christina Montes буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 5
За всё время: 171
