The Samsung Galaxy Note 4 is a cellular smartphone that was released in October 2014. The Galaxy Note 4 Model Number is SM-N910, SM-N910A, SM-N910T, SM-N910V, or SM-N910R4 for American variants.
262вопросов Показать все
Half screen Frozen on right side display
When using phone, the right side of the screen becomes frozen and will not change.
Have to turn off and let set for several min. before it restores to full screen. If I turn
off the phone during the freeze, the right side goes all "fuzzy" like when you change
the TV to a dead channel.
Это хороший вопрос?
Оценка 3
1 Комментарий:
please tell the solution
из
Добавить комментарий
2 Ответов
I got it fixed. It turned out to be the faulty battery that caused it. Strange but true. I replaced my battery with Duracell battery for Note 4 and the problem disappeared ever since. Hope this helps.
Был ли этот ответ полезен?
Оценка 0
just change it & display will be ok
Оценка 0
1 Комментарий:
“change it" what?
you indicated a pin apparently?
can you please elaborate?
thank you @maikei
из
Добавьте свой ответ
Joseph Bledsoe будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 2,494
