Why don't my daytime running lights work
My daytime running lights on my 2003 Toyota rav4 stopped working my headlights only work when I put them on high beem.
Это хороший вопрос?
Это хороший вопрос?
Jose,
First thing. Daytime runners are to be on when the headlights are off. Now the RAV 4 may possibly be setup to "add" them with the high beams, which may be why your seeing them.
Like the first answer said. Check the fuses, inside car and under the hood. They run through the head light switch, which could be problem.
I'll look into it and see if there is anything to be found.
Был ли этот ответ полезен?
За последние 24часов: 2
За последние 7 дней: 10
За последние 30 дней: 12
За всё время: 1,127
1 Комментарий
i would check your fuses, and then if all fuses are good try a new bulb.
из Candido Ortiz
