A1708 / EMC 2978 — Released October 2016, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar). The function key version packs an Intel Core i5 and two Thunderbolt 3 ports.
208вопросов Показать все
Can the SSD be switched out?
Can the SSD be switched out and upgraded ?
Это хороший вопрос?
Оценка 8
Добавить комментарий
7 Ответов
Наиболее полезный ответ
Looks like the entry level 13" isn't soldered
OWC noted the following points in its teardown.
– Bottom was more difficult to remove than previous generations, but it was not glued.
– Speaker module needs to be removed to pull SSD back.
– SSD had very strong tape covering the interface port.
– Laptop automatically turns on when you open it regardless of pressing power button.
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
If you review the OWC vid you'll also see the SSD module is very different from the older systems and it looks like a custom part! So, even if its removable, it will be a while before we see a 3rd party option.
из
@danj Yes I saw that! Hopefully the wait isn't as long as it was for the Retina models!
из
http://blog.macsales.com/38440-ssd-in-la...
Оценка 1
Yes, Please look at
Оценка 1
Yes. But so far no one has made an SSD that is compatible with this model, the first few will begin to pop-up within the next few months.
Оценка 1
Yes is it removable.
Update (10/31/2016)
Оценка 0
2 Комментариев:
Do you have a back up link on this?
из
I would like to know where you got this information. Nothing on the internet says Soldered, but I wouldn't put it past them
из
Anyone here who knows the pinout of the new SSD?
Оценка 0
Adapter for MacBook Pro 13” 2016/2017 nTB
https://www.globalmac.cl/Adaptador-SSD-M...
(Chile)
Оценка 0
Добавьте свой ответ
benkuza будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 5
За всё время: 7,917
