will power up but its a black screen on the moniter
ok i have a Dell Dimension 5150 / E510 i first had the problem that i could not get my desktop to power up none at all ok so i went through the process of checking everthing then bought all new parts , new power supply, new memory ,new io panal and new cpu , so i went ahead an bought a new motherboard as well when it didnt fix the power up problem, but now it will power up and the power button is an amber color and it does not show the start up screen anymore an its just black a black screen. i have all new part and motherboard and it still is not working
Это хороший вопрос?
2 Комментариев
When I turn mine on it comes up with a black screen and it shows on the top left of the screen the text: RV370 P/N 113-A62801-106 BIOS and IDK what to do?Help plz?
из Riley Tuffs
Hi @rdtmmii,
You may have a faulty RAM (memory) module
Try removing all the RAM modules and just reinstall one at a time to see if it boots properly. test them all to see which one doesn't work.
WARNING!!!
"Always have the PC switched off and the power disconnected from the PC when you remove and install RAM" Do it every time, you could damage good RAM if you don't.
из jayeff
