Tv powers on then off within a minute
Sanyo DP55441 Tv powers on then off within a minute
Это хороший вопрос?
Это хороший вопрос?
Is there any video input to the TV because many new TV's will turn off after about a minute if there isn't any video signal detected. Try connecting a DVD player and play a DVD then turn on your TV. Then if it doesn't stay on then in the correct Input mode in this case either DTV or DVD or even Aux. Whatever input you use the TV should now show it. If it still turns off then it is probably a power issue.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 74
@patrick0412could be a power board issue. Open the back of your TV and take a look at the boards. Post some images of what you see with your question. For that use this guide Adding images to an existing question
из oldturkey03
