This device page will show users how to replace various parts of the Cannon PowerShot SX260_HS. these things including LCD Screen Replacement, Motherboard, Battery, And Shutter button
11вопросов Показать все
Why won't my zoom lens close?
My zoom lens stays part of the way open at all times. It won't close or open. It's stuck in this position. The camera will turn on and run then the bell rings four or five times and then I get a message on the screen saying that "Lens Error camera will shut down automatically." It then shuts down.
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
Jan Frank most common error on digital cameras and can be caused by numerous issues. Check on here for some ideas on what to try. Most of the time this will not totally fix the issue so you may consider replacing the lens assembly. These guides will at least get you into the vicinity of your lens. Also check this video for further help.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Jan Frank будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 6
За всё время: 1,029
