computer won't boot, hard drive error
can't seem to get my computer to boot up to windows logo, I keep getting this hard drive read error.
Это хороший вопрос?
Это хороший вопрос?
Ok. Since the Laptop Was Dropped. We Need To Check And See If The Hard Drive Was Knocked Loose From Its Tray. Whats The Exact Model Number Of Your Laptop. We Have Acer Aspire 5334 There Should Be Four Other Numbers. Most Likely Your Hard Drive Was Knocked Loose And The Laptop Cant Find It.
On The Bottom Of The Laptop There Is This Cover. Big And Long. Take A Screwdriver And Remove That Cover. Take A Look Inside And See If The Hard Drive Is Knocked Loose.
If It Did. Just Slide The Hard Drive Back Into The Connector.
Let me Know What Happens :)
Был ли этот ответ полезен?
I Hope This Fixes It. Because Other Wise The Hard Drive Might Have Been Damaged. Does The Hard Drive Make Any Noises Upon Turning On The Laptop. Clicking, Ticking etc
thank you so much, i followed exactly what you did, and everything works just fine now.
what is the error message that hard drive is giving? Did you try to reinstall the Operating System? If you did, did you receive any error messages? If so what were they?
I reinstalled operating system and everything works fine now. thank you
За последние 24часов: 1
За последние 7 дней: 9
За последние 30 дней: 9
За всё время: 4,098
2 Комментариев
Did The Computer Recently Get Dropped ?
из Carl Beebe
yes my sister recently dropped.
из gilson teixeira
