The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
426вопросов Показать все
Xbox one S - Optical Drive remplacement
Hello,
i'm back to you because i just had a discussion with xbox technical support, and they confirmed that the remplacement of the optical drive is paired but in a easier way.
it mean's that i dont have to swap the PCB like the old version, can anyone confirm this information please ?
thank you.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
It's exactly the same as with the Xbox One. You have to swap the drive board to the replacement drive. I can do that for you if you need. Just click on my name to get to my business contact info.
Был ли этот ответ полезен?
Оценка 1
Наиболее полезный ответ
"Xbox technical support"? I assume you are talking with Microsoft.
It's easy for them, they have the tools to change pairing. So for them it's just replacing the whole drive and use the software to reset everything. However we don't have that tool so it is not possible for us.
Оценка 2
Добавьте свой ответ
oussamaamrani будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 547
