Дата выхода 25 сентября 2015 г. Модель A1688 / A1633. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 64 или 128 ГБ памяти; в цветах: Серебристый, Золотой, «Серый космос» и «Розовое золото».
2682вопросов Показать все
How do I get rice out of headphone jack?
So I dropped my phone in the ocean and it automatically started saying I was in headphone mode but I wasn't. I then got home and put in rice hopping for it to get rid of extra moisture/dampness from the drop. I then had a look up the headphone jack and saw I had a piece of rice stuck all the way at the top. What should I do? Any answers would be appreciated
Это хороший вопрос?
Оценка 5
Добавить комментарий
7 Ответов
Выбранное решение
@katescarbrough since you hopefully found out by now, rice does not work. It is the equivalent of doing nothing. The very first thing you want to do is to not try to restart, sync or otherwise trying to use the phone. This may further damage your phone. The next thing to do is to clean it. Disassemble your phone using these guides . You must remove all EMI shields. If you do not remove those, you might as well not do anything. After you removed those, clean the whole board, connectors and all with +90% isopropyl alcohol. Follow this guide , and even so it was written for a 3G all the points are still pertinent to your phone. While you clean your board, check for any obvious damage, like burned or missing components etc. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, reassemble your phone and reevaluate. To remove the grain of rice, you can try a small needle and a vacuum to see if you can break it up and remove the fragments with the vacuum. Otherwise you will have to replace the lightning connector. Use this guide for that. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
Rep: 1
iPhone Изображение
Инструкция
Repairing iPhone Liquid Damage
Сложность:
Сложно
1 - 2 hours
iPhone 6s Lightning Connector Assembly Изображение
Инструкция
iPhone 6s Lightning Connector Assembly Replacement
Сложность:
Модерировать
1 - 2 hours
Был ли этот ответ полезен?
Оценка 10
7 Комментариев:
She just wants to get the rice out the headphone jack bro
из
Catt Jure that has been addressed in the original answer as well. Just covering all the bases :-)
из
So my phone works nothing stuck or anything but it dropped in the toilet for like 5 sec and it says I have headphones in but I don’t so what do I do?
из
i did all that but the rice went up the charging spot and now wont turn on now
из
I used rice today it fixed it no need for all that crazyness
из
Показать 2 больше комментариев
I just used a toothpick and it came out.
Оценка 4
actually rice does work. or at least i hope so. i dropped my phone in water five minutes ago and i put mine in rice. i dropped my old phone in the pool when i was at the beach and when i dropped it in the toilet and i put rice on it and it helped. im just hoping for the best. and all you have to do it use a toothpick.
Оценка 0
2 Комментариев:
rice only works when it's directly in contact with water. It's better to use those silica gel packets you find in shoes etc.
из
Rise or silica don’t disappear corrosion
If phone turned on after rise he will turn of also with no rise its a matter of luck and condition of the damage inside
If person died let’s put him in bat of redbull he will start to run?
из
The needle and vacuum trick is pretty useful
Оценка 0
i put mine in rice cause i was being an idiot and dropped it inside of soup and so rice got stuck in it i tried using a needle that just broke it and i tried a pushpin which did a lot more help and got the rice out. Works well
Оценка 0
I used a needle and it came out 1,2,3
Оценка 0
Yep - just to add to the voices on this. A needle. Takes about 2 seconds and the issue is resolved and you can move on with your life. Thanks ifixit hive!
Оценка 0
1 Комментарий:
I used a needle an it pushed the rice in now what do I do
из
Добавьте свой ответ
kate будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 8
За последние 30 дней: 31
За всё время: 80,583
