The Polaroid PMID4312 is a 4.3" tablet that features a multi-touch display, front facing camera and utilizes the Google Play store to obtain apps.
I can't listen to music
I am trying to listen to music, but I can't hear anything even though, I raised the volume to maximum.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
First of all you need to know if the problem it's only with the speakers or is a software issue.
Try to go to settings and look for the volume settings to be sure everything is on the top level.
- If that is checked and it's still not working then try to use a headphones to check if works that way.
-I am assuming you already tried to reset the tablet then if nothing works, the problem for sure will be hardware, now you need to open the tablet and look for a lose connection with the speakers inside.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Donald Korca буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 8
За всё время: 120
