were is the crankshaft sensor located
i have a 1999 plymouth voyger2.4l dohc i cant locate the crankshaft sensor
Это хороший вопрос?
Это хороший вопрос?
Chrysler 2.4 crankshaft position sensor is bolted in lower engine block, behind the engine (engine side facing the vehicle's firewall) look above the oil filter adapter from under car. Crank sensor held/secured by a bolt, remove bolt and sensor will come out with a little pull/twist force. Links below show the location and how to test crank sensor. Good luck.
Был ли этот ответ полезен?
I got a doge 2006 caravan 3.3 where my crank shift seneror at
За последние 24часов: 1
За последние 7 дней: 10
За последние 30 дней: 43
За всё время: 5,560
