The Bose SoundLink Color is a Bluetooth speaker, designed as a more affordable and portable alternative to the SoundLink Mini.
38вопросов Показать все
Bose Soundlink Color charges but does not turn on!
Hi,
For some reason my Bose Soundlink Color charges fine and is now fully charged as it quickly flashes the green light when you plug it out, however, it DOES NOT turn on.
I've tried the Bose Updater, but I don't think it even recognizes my device as it doesn't do anything. It worked fine about 4 days ago so I don't know what happened and why it's not turning on.
I've tried the 15 second play/pause button, I've tried doing Factory reset... and it can't be my battery since it's fully charged?
Somebody please help me!
Thanks in advance
Это хороший вопрос?
Оценка 1
Комментарии:
Hi, Does it turn on when you have the charger connected and switched on?
из
@jayeff The charger is connected and the speaker is fully charged as it's showing the green battery light. However, it does not turn on. Very sad...
из
Me too same problem
из
When i tried to charge it .it shows the green light and after 3 second the green light disappear and it wont turn on even in charging
из
I've exactly the same problems. Anybody got solution to this problem? Is the battery run out?? Anybody tried Bose customer care center?
из
Показать 2 больше комментариев
Добавить комментарий
3 Ответов
Выбранное решение
Hi,
If the speaker is out of warranty and as as you have tried a factory reset which hasn't worked, my only suggestion now is that you try a power 'reset' and see if this will resolve the problem.
To do this you will have to open the speaker and disconnect the battery. This will require you having soldering skills and tools. Once you have disconnected the battery, press and hold the power button for 20 seconds to dissipate any residual charge in the device and then release the button.
Once this is done reconnect the battery (be careful to reconnect the wires to their correct connection points) and try turning on the speaker and see if it has been restored to normal operation.
Here is the relevant Ifixit guide to remove the batteries in your speaker.
Bose SoundLink Color Battery Replacement
Был ли этот ответ полезен?
Оценка 3
Комментарии:
Thank you for your help
из
Did this help in your case? Before I open up my bose, I'd like to know if it resulted in anything.
из
What size are the Torx security screws. Thank you
из
Connect to the computer. If you hear the chirp that a USB device is connected, but it still wont turn on or work, try to update the firmware at the Bose Official Update site:
http://btu.bose.com
Оценка 1
I did have the same problem, here’s what I did.
  1. used original cable and charger
  2. got the amber power light to flash
  3. did the “press Play/Pause for 15s; disconnect power” reset.
  4. turned unit back on, and immediately did a factory reset by holding aux & - buttons together
  5. paired my Bluetooth device again
  6. it has been playing for half an hour now, but cannot turn off the unit or switch sources. It is basically frozen in the ON/Playing state.
I’ll need to go through the above steps to use it every time.
Оценка 0
Комментарии:
Hi, regarding the step 4. AUX + all buttons? or AUX + Play/pause button only? THanks.
из
Добавьте свой ответ
Zoe Farah C будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 31
За последние 30 дней: 148
За всё время: 16,268
