Xbox One — третья по счёту игровая приставка от компании Microsoft, являющаяся преемником Xbox 360.
727вопросов Показать все
Why won't my Xbox One turn on?
My Xbox One hasn't been able to turn on for a while. I've tried every suggestion on www.xbox.com but it still won't work. When I turn it on,my controller will start blinking and it won't show it on the screen. If anyone can help,that would be great.
Это хороший вопрос?
Оценка 1
8 Комментариев
Does the console itself come on (Does the light on the front come on and stay on)?
из
No,it hasn't turned on like that since I bought it.
из
Is it still under warranty?
из
What color is the light on the power brick? And does it change when you try to power on the xbox? (Don't use controller) also does it make the "ding" sound when you try to power it on?
из
I'll try that out today. And it isn't the power brick.
из
Показать 3 больше комментариев
Добавить комментарий
3 Ответов
Выбранное решение
If you just got the Xbox from someplace like bestbuy it will be under warranty for about 1 year after purchase so just get the free replacement if you got it from a friend check if it's still under warranty at Xbox.com if it's not and it's not the power supply you can have Microsoft repair the console if the tampering sticker is not damaged that would be your best bet, if you would like to have me help troubleshoot I am here to help
Был ли этот ответ полезен?
Оценка 2
Well,here's the answer: A Fallout 4 Mod (Blacksmith Anywhere) has fried my motherboard and it circuits from the system. Only 2 options: Check for warranty and send it to Microsoft to fix it or just buy a new one.
Оценка 1
from my experience i could say that is changing the power supply is the solution because it is more familiar that it is power supply issue in xbox.
i wish this helped you :)
Оценка 0
7 Комментариев:
does my answer helped or there is other answer?
из
Other answer,but this is still helpful for other people with this problem.
из
could you please let me know that answer plz..
из
That may be the answer but we still have not determined the problem, I.E. power supply or console
из
I'm waiting to know the answer ...
plz make it done Danny .
из
Показать 2 больше комментариев
Добавьте свой ответ
Danny Camacho будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 6
За всё время: 6,205
