My 3ds won't charge anymore
My 3ds won't charge the battery, I've tried multiple chargers and a docking to try it, but notting works. I think it has something to do with the charge port but I am not sure.
Это хороший вопрос?
Это хороший вопрос?
@dpesser , David, could be a faulty charge port, first check for dust debri and blow it out, also look inside to see if contacts are bent and straighten with a pin if bent. Could also be a faulty battery if older consider replacing it.Links below for trouble shooting and replacing charge port and a link to charge port and battery for 3DS. Good luck.
https://www.youtube.com/watch?v=oZrprlK7...
Был ли этот ответ полезен?
Thanks for the response, I will try it out.
За последние 24часов: 2
За последние 7 дней: 31
За последние 30 дней: 119
За всё время: 35,031
1 Комментарий
I also had this problem. It is fixed now. In my case, it was a problem with the outlet box (the part that connects with the outlet). The problem was that a wire had disconnected from the plug in part (sorry I don’t know what parts are called). I hope this could be helpful. Just a reminder to check all parts of the situation before sending your device in.
из Adam Dequaine
