Why Does my Reception Keep Dropping Out after Refurb of Chassis
Hello all,
I am posting to ask why the reception in my refurbished iphone 6 keeps dropping out?
The iphone had the entire chassis replaced as the old one was too badly bent & damaged.
Is it possible the after market chassis+parts are to blame for the reception errors?
Or is it possible from the previous drop, the reception components on the logic board broke? Would the either work 100% or not at all?
Any help is appreciated , thanks!
Это хороший вопрос?
Maybe from the dropping. Did you changed the housing? Maybe one of the antennas plugs is not connected or not seated connected.
из Alex
I changed the housing to a non-OEM housing, it had signal issues. I switched to an OEM housing, it still has signal issues. I think its to do with the logic board. Is it fixable ? ;(
из ZsTech
There is most likely a missing antenna screw that connects to the housing. OR you need a new dock connector OR- now im not 100% sure about this but - maybe a ground connection to the dock connector? Can someone correct me if the last statement is completely wrong?
из Krazy Kat
