Why can't my printer connect to my wireless network?
My printer doesn't seem to be able to find my home wireless network. When I turn my printer on, my home wireless network doesn't appear. What can I do?
Это хороший вопрос?
Это хороший вопрос?
This could be due to a number of reasons. To troubleshoot, try connecting another device in your home to your wireless network to make sure the network is working. If not, you may need to restart your router/modem. Make sure your printer is within the range of your wireless router, and that it is not placed near a microwave, cordless phone or large metal objects.
You may need to check your router's MAC settings - these could restrict new devices from being able to connect to your printer. If settings are in place, check the MAC address of your printer and register it with your network (check guide linked below on how to find the address). Additionally, you may have to input the name of your network (SSID) manually if it doesn't appear, or check to make sure the WEP/WPA keys are entered correctly.
For more troubleshooting info for network connectivity, visit the printer's user manual.
Был ли этот ответ полезен?
The printer worked fine over the weekend, Monday I needed to print something and the printer couldn’t be found. On checking the printer it was off line, went to WiFi set up, my SSID wasn’t listed so manually entered it. Failed! Several attempts and the printer is not finding my network. It finds others and, as I said, won’t manually connect to mine either. Epson XP-332
In the sections to come, you will gain knowledge about how to connect Epson printer to wifi on multiple systems, such as Mac, Windows 10, etc. We will share with you several procedures for connecting the device to wifi. We have explained all the ways and also defined the steps. Make sure that you read all the steps first to avoid making any mistakes.
Let’s begin connecting Epson printer to wifi network with the quickest, simplest, and shortest procedure. We will tell you how to establish this connection by using the “Epson support”. You can perform this procedure in only 10 steps.
1. First, ensure that your Epson printer is configured to a wireless network or an Ethernet connection. For this, click on the “Epson support” main windows and choose your printer model.
2. Go to the “Manual” section and then press “Start” to begin the procedure.
3. Now, download and install the “Epson connection printer set-up utility”.
4. You will see a window that displays the “License Agreement”. Click on the checkbox showing “End-user license agreement”.
5. Then click on “Next”.
6. Press “Install” and then click on “Finish” when the installation is complete.
7. Now, from the “Dialog box” menu, click on the printer that you have installed and press “Next”.
8. Go to the “Printer Registration” option and press Next.
9. Now, click on “Agree” and press “Next”.
10. A new dialogue box will be displayed showing the message “Register a printer to Epson Connect”. Press “Ok”.
Here is a procedure to help you connect your Epson printer to wifi on your Mac. In this procedure, we will tell you how to connect your device to wifi via the Epson Connect printer setup utility application. Read all the 17 steps given below to perform this procedure without any hassle.
1. Search for the ‘Epson Connect” printer setup utility application.
2. Download the application on your Mac.
3. Now, run the application and tap “Continue”.
4. You will be prompted to “Agree” to the software license.
5. Click on “Continue” after agreeing.
6. Now, install the application.
7. Next, click on “Agree” to accept the terms and conditions.
8. When the installation finishes, choose the product and hit “Next”.
9. Click on “Printer Registration” to continue.
10. A dialogue box will be visible with the message “Register a printer to Epson Connect”. Hit “Ok”.
11. Read the terms and conditions and press “Next”.
12. If you do not have an account, create a new one.
13. To register a new product, choose “I already have an account.” Then press “Close”.
14. Click on “Activate Scan to Cloud and Remote Print” to activate the services.
15. Your Epson printer will be connected with Epson Connect. Open the “Settings”.
16. On your Mac, go to the wireless network connection options.
17. You will be asked to enter your password and your device will be connected to wifi.
The method to connect your Epson printer to Wifi on Windows 10 computer or laptop is absolutely simple. We have described this method in just 12 steps. Before you begin reading these steps, we will advise you to check that your Epson printer has been turned on and is connected with your Windows 10 system.
1. On your Windows 10 system, press the “Windows” key and the “Q” key to open “Cortana”.
2. In the search box of windows, type “Printer” and tap the “Enter” key.
3. You will see the “Control Panel” and the connected devices. Choose your printer.
4. In case you cannot find your printer, ensure that it is on and connected. Then click on “Add a printer or scanner”.
5. Choose your Epson printer from the list.
6. Double-click on the printer’s name. Then tap “Set up”.
7. Go to “Wifi settings”.
8. Click on “Wifi setup” and enter the wifi setup wizard.
9. Find and click your network’s name.
10. You will be required to provide your password.
11. Now, tap on “Connect”.
12. Your Epson printer may take a while to get connected with your wifi. Once connected, its signal strength will be visible on the bottom-right corner of your Windows 10 system’s screen.
If you can’t access wifi on your epson printer. it shows the error related to the computer or network. here in this artilce, I am sharing the instructions to fix the problem.
So these are the steps to fix the Epson printer won’t connect to WiFi. If it doesn’t get fixed. let us know we will help you in fixing the problem.
Have the same problem.. primter appears connected to wifi on my mac and epson 3760 printer but doenst send print.. printer says excellent connection.. i have another epson 2610 that is connecte and working fine.. i already reseted my router.. disconwcted lower aupply and restarted it and nothing.
Most of the time, people go through wifi problem. due to the wifi encryption problem. when users changes there password or encryption type on their wifi. but don’t delete the existing profile on your their network. they face such kind of problem. so you should delete the existing wifi profile from your wifi and try to connect your printer to the wifi. I am sure this will work fine this time.
Yes, thank you this was exactly my issue.
I found with our EPSON ET-2760 it will not find our SSID utilizing google wifi because of the special character: “‘“ (apostrophe). I made a guest network without a special character and it immediately sees it. It only sees some special characters. I have 63 devices on my wifi so I’m not going to change my SSID. I guess the answer is to flip networks when I need to print.
Thank you. This was the issue I have been struggling with tonight and your answer was the one that identified my issue. Have to say that I'm disappointed with Epson's software not being able to handle this It is such a basic function at this point.
I agree! Such a super easy thing for them to fix and it boggles my mind that they have special characters omitted.
Connecting Epson printer to Wi-Fi network is an easy process and can be accomplished in 7 steps without needing any prior technical knowledge. The process of connecting the printer to Wi-Fi is as follows:
Voila! Your Epson printer is connected to the Wi-Fi network.
most printers don’t support ADHOC WiFi
most phones can’t create AP WiFi networks, they only work with ADHOC, it’s a limitation of the wifi chip in the phone.
Try reconnecting to the network, which must be 2.4 G. If it wouldn't connect turn it off, unplug it and try again. That worked for me. As an aside, I’ll never buy another Epson printer. It’s been a pain, but does seem to work better with the windows machines on my network.
Presumably wifi sourced. Try putting a reflector of kitchen foil behind your modem facing the printer.
My EpsonL4260 was connected to our wifi network just fine and then it suddenly stopped connecting and wouldn't even see our wifi signal. I turned out that the WPS button on our D-Link wireless router had gotten bumped and all I had to do was press it again (just for a moment, if you hold the button in for several seconds, it will reset the router which you do not want!) and voila! our SSID appeared again and we were connected!
Reboot or Unplug to Start Fresh.
Move It Closer to Your Router.
Remove and Re-Add Your Printer in Windows.
Update Your Drivers and Firmware.
Plug the Printer Into Your Router Directly.
Connect to a PC and Share.
Regards,
Will
За последние 24часов: 7
За последние 7 дней: 48
За последние 30 дней: 211
За всё время: 84,735
3 Комментариев
please I need my time not to be waisted, I just want to be connected to my Epson printer and scan WF-2750
из mrsmmoyo
Hi there, I don’t have router but I connect all devise in my mobile so how i connect to my printer f……
из muhmood mahmood
can not printer working on my epson et4550
из pmort49@bigpond.net.au
