A television game console produced by Sony Computer Entertainment; the PlayStation 4 Slim (CUH-2000 Series) is a thinner replacement model for the original PS4. Announced September 7, 2016.
564вопросов Показать все
no video signal when turned on
ok, i just bought a brand new ps4 slim last black Friday.and I am having this issue that when I turned it on sometimes it just doesn't give me any video signal. (i can hear it , I mean it turns on ) what could it be? then I try rebooting it but the same result unless I unplug it from the outlet and then it starts normally. help please
Это хороший вопрос?
Оценка 0
1 Комментарий:
Check that the HDMI port isn't loose. Does the light turn white?
из
Добавить комментарий
1 ответ
Make sure the PS4 is connected to the correct HDMI port.
Try unplugging and re-plugging the HDMI cable in again to make sure you have a secure connection. If it's connected to the correct port, you could switch it to another available port and try again.
Also make sure your PS4 is up to date in updates and make sure you vents are cleared of dust and it's not in an enclosed cabinet for it to overheat.
Simple solutions but that's all I can offer besides suggesting it being serviced again.
https://www.partitionwizard.com/partitio...
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Alian Villazan будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 176
