Операционная система Apple для настольных и портативных компьютеров Mac.
Why won't my Air show a startup disk after formatting
After formatting my macintosh hd, I went to reinstall Mac OS X Lion. Won't load past beyond Apple needing to verify my computers eligibility, the time it has it prompt me for a "access key password" which I am unaware of. So I choose to select a starter disk, but it shows no disk to choose from. What do I do??
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Instead of trying to jump through a ton of hoops with apple you can instead reinstall your operating system using internet recovery mode INSTEAD of installing from a drive or disc, attached is a guide to booting into internet recovery mode, follow this guide step for step as it tells you how to format your drive using disk Utility to make it compatible with Mac Os again before selecting install Mac Os, the guide can be found here: How to use Internet Recovery to install macOS to a new SSD
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Damian Reynoso буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 148
