The Samsung NX1000 is a digital smart camera that was released April 2012
I can not remove the native objective lens. lens is blocked.
I can not remove the native objective lens. I press the removal button, the lens is not removable. Lens is blocked.
Не могу снять родной объектив. Нажимаю кнопку снятия, объектив не снимается.
Update (12/08/2016)
It is not simple. I have to unscrew the lens before. And I know how to unscrew. However, already half a year can not unscrew the push of a button. I can just strip the threads by following your advice.
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Press the button, then rotate clockwise or counterclockwise. Simple.
Был ли этот ответ полезен?
Оценка 0
3 Комментариев:
из
You must hold down the button down as you rotate the lens. I do not see how it can be blocked, please explain how it is blocked.
из
I have a similar problem. Camera indicates Lens error oo when power on. Problem with the lens is that the zoom barrel will not turn. I have followed the advice above with regard to the small button and then trying to turn the barrel of the lens but to no avail. I think fffosrab has the same problem, but is just describing his fault as blocked rather than locked or jammed. Watched a video of opening up the lens but not sure I want to do that...
из
Добавьте свой ответ
fffosrab будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 177
