The Samsung Galaxy Ace is a low-end, slate-format Android device released by Samsung on February 2011. Identifiable by model numbers GT-S5830(i, B, C, L).
Вопросов 20 Показать все
Battery power is draining too fast.
When it charges, the time of charging decreases from Hours to Minutes. Also at disconnecting the charger, the power battery decreases. Also at seeing WhatsApp photos, videos, etc... it drains faster. Is there a way to fix the battery?
Это хороший вопрос?
Оценка 0
1 Комментарий
Also, that Samsung Galaxy Ace is not mine.
из
Добавить комментарий
Ответов (1)
Выбранное решение
Santi12008, You do not state what device you have or how old. Your devices battery may be near its end of life or faulty. Maybe replace the battery and use the information below, tips and tricks on extending battery life and usage. Good luck.
http://www.digitaltrends.com/mobile/how-...
http://www.makeuseof.com/tag/how-to-make...
http://www.pcadvisor.co.uk/how-to/mobile...
Был ли этот ответ полезен?
Оценка 2
4 Комментариев:
The samsung galaxy ace is 4 years old
из
Santi12008, Yes, 4 years old, probably time to replace the battery. I hope this helped you out, if so let me know by pressing the helpful button.
из
Where i can buy a Samsung Galaxy Ace battery? It said the battery is going weak
из
Santi12008 , Probably best for you to do a web search for the battery for closer availability, if not see link below for replacement battery.
https://www.aliexpress.com/price/samsung...
из
Добавьте свой ответ
Santi12008 будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 2,745
