Will I void my warranty?
I have a mac that has a broken motherboard caused by the GPU. I had constant crashes and GPU panic and it suddently stopped turning on.
I called Apple and since its still under warranty, they said they would fix it for free. However, I had a hinge that was loose that I tried to fix myself earlier. I broke the T8 screws and have some missing cover screws. I never touched the motherboard tho. Will I still get the free or does it void my warranty?
Это хороший вопрос?
2 Комментариев
It's going to void warranty most likely. If you want to be safe get the paint chipped / threaded screws replaced with new ones and new bottom metal cover screws.
Clean any fingerprints inside the MacBook if you see any as well.
из Ben
How do I remove this screw?
[image|990494]
из Thawng
