2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
274вопросов Показать все
Where I can find the OEM Battery?
I want to know where I can fin the OEM replacement battery for my Macbook Pro 15 Retina Early 2013 A1398 . I saw one on this page but is out of stock but I still don't know if it is compatible with my model any help please.
Это хороший вопрос?
Оценка 4
Добавить комментарий
3 Ответов
Выбранное решение
It’s currently in stock and also carries a 1 year warranty!:
MacBook Pro 15" Retina (Mid 2012-Early 2013) Battery
MacBook Pro 15" Retina (Mid 2012-Early 2013) Battery Изображение
Продукт
$79.99
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
Yes, but I said OEM. I see several complaints this isn't good as OEM.
из
Then you'll need to visit Apple and let them fix your system. No one offers new OEM batteries (other than Apple). You could find a used battery and that's about it.
из
You won't find an OEM battery for any Apple computer unless it is taken from another computer. Apple does not sell parts to their products, I would assume, because they want you to pay the costly markup of them fixing it for you.
I highly suggest giving the new one (it is stated to be up to OEM Specifications, otherwise just as good, if not better, than the original Apple part) on this website a try - I did, and it's working great. The repair process was rather tedious and lengthy, but worth it if you don't want to invest $2,300 or more on a new MacBook Pro. It was also for an A1398 Model, Early 2013 15" Retina.
Оценка 1
@elvisgonzalez I found this and says the brand is apple and the guy has a 99.2% positive feedback.
http://www.ebay.com/itm/Original-OEM-Bat...
Hope this helps!
- Jainore
Оценка 0
3 Комментариев:
It says out of stock and it says doesn't fit 2013 models but thank you!
из
I think that one would not fit my mackbook because its late 2013 :/ and mind is early 2013 but thank you for trying to help!
из
Добавьте свой ответ
Elvis Gonzalez будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 15
За всё время: 2,496
