4 inch display / Available in a variety of colors / Released in 3 different models / 16, 32, or 64 GB capacity
331вопросов Показать все
After battery replacement, screen has multi color lines
Thanks in advance for the answers. I replaced the battery on my ipod touch 5th generation and when I turned it on, I got vertical, multi color lines on the screen, which come on for a few seconds and then disappear for a few seconds. From what I can gather I damaged the screen, but I'm not sure how. Any ideas? What do I do next?
Charlie
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Hello,
This could be an issue with the cable that connects the screen the Logic Board. To clarify, do the colored lines appear then disappear after a period of time, or are they on all the time? Also, to better assist you, could you please provide me the model number if the iPod?
Thanks!!
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
The model number is A1421. The colored lines appear and then disappear, about every 5-10 seconds. Thank you for the help
из
Thanks! The best answer I can think of is 1) cable from screen to logic board or 2) logic board itself is damaged.
из
Добавьте свой ответ
Charlie будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 92
