Why isn't my iPhone turning on?
So basically, my iPhone died yesterday and I put it in the charger. Before it died, it had some issues with the charger going in the whole, it was like it couldn't go in all the way and I had to bend it at a crazy angle for it to charge. Nothing was wrong with the charger, I tried it on other devices and it worked fine. So I kept it there for a few hours and it was still showing the red battery screen, nothing else. That was weird because usually when it dies, as soon as I plug it in, it starts up again. So I looked stuff up, tried holding the power and home button on, tried the hairdryer trick... nothing worked. Now the phone wont even show the red battery screen. It's pitch black. I'm at my wits end. What should I do? I left it to charge overnight and nothing happened.
Это хороший вопрос?
1 Комментарий
It could quite honestly be both the battery and charge port! Also adding too much heat to your screen could have caused the LCD to burn out. I would get in the device and start by disconnecting the battery. Sometimes it is is just that simple. If this doesn't work, your only really option would be to start trying new parts. I also know that there is currently a recall on some models of the iPhone 6s. It is worth looking into, that could solve your problem and save you some money.
из Alex Montgomery
