Repair guides and support for Lenovo's line of consumer-oriented laptops, the IdeaPad series, first announced January 2008.
1082вопросов Показать все
No audio output device installed
There is no audio output device installed on my Yoga 710.
Это хороший вопрос?
Оценка 2
5 Комментариев:
Hi,
What OS is installed in your laptop?
Is there an entry listed under Sound, Video and game controllers for an Audio controller? If so is there a red cross or yellow exclamation mark next to the entry? Go to Control Panel > Device Manager > Sound, Video and game controllers.
If nothing is listed there, is there a listing under "Other Devices" (if mentioned) in Device Manager for an Audio controller?
из
same problem here with a Lenovo yoga 710. Intel display audio is listed under sound, video and game controllers. Intel high definition audio under other devices. I've tried scanning for hardware changes and disabling then enabling the devices. hasn't worked. For some reason when I try to scan for new drivers it can't find any. Ive tried manually downloading and installing the audio drivers from Lenovo, and this hasn't worked either. Running out of ideas here...
из
Hi @duder1313
Have you tried uninstalling the Intel High Def audio in Other Devices, (and possibly the Intel Display audio as well), restarting the laptop and letting Windows 'find' any new hardware and see what happens?
из
there is no audio output my lenovo ideapad 100
из
Hi @caynab ,
What OS is installed?
What have you checked? e.g. Device Manager, audio from headphone jack, sound not muted etc
The more info you give the more relevant the answers
из
Добавить комментарий
1 ответ
If your laptop’s audio is distorted or does not work, see the Lenovo IdeaPad U530 Touch Has Distorted Audio problem page for possible causes and solutions.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Bjbj будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 2,045
