Dropped portable hard drive
I dropped my portable external hard drive. Can I still recover all the files inside my external hard drive?
Это хороший вопрос?
Это хороший вопрос?
Is this the ssd version or hard disc? If its the hard disc will it power up does it click? If it clicks you can make it work enough to recover data. This video may help
https://www.youtube.com/watch?v=F5Y7Bnia...
Try to be as clean as possible when preforming the task of opening the hard drive . Try to keep dust to a minimum.
Был ли этот ответ полезен?
The power up still functioning but i doesn't blinking and also i hear a noise inside the disc beeping.
Can i still recover all the files in my portable external hard drive?
Fix for a beeping hard drive https://www.youtube.com/watch?v=7m5cil6K...
Once you get it to work make a copy of your important file odds are it wont last long
yea i dropped my one an it has the click of death nowso imtryin to copy as much as i can will this &&^& it up?
what if it doesn't click, but lights blink and whirring sound inside, sometimes it lets me unlock but won't go any further
It is possible the data can be recoverable, however you need to make sure NOT to plug it in anymore and send it to a Certified data recovery company for help. mobdro app
It is possible the data can be recoverable, however you need to make sure NOT to plug it in anymore and send it to a Certified data recovery company for help. [http://<a href="https://mobdrotvapk.com/">mobdro</a>|mobdro]
My WD passport fell on the floor…now there is a clicking sound and not loading once plugged into device… how can I retrieve files from the external hard drive
Did you fix a fix?
За последние 24часов: 2
За последние 7 дней: 27
За последние 30 дней: 112
За всё время: 93,841
2 Комментариев
my WD is dropped and whenever i plug in it asks me to format the Drive G? so is it possible to recovery my files back ?
из Frieda Vance
I dropped my My Passport Ultra, and is makes a whirring sound, but does not link up with my computer. Can I recover my data on the disk?
из William Brown-Jensen
