Power steering fluid or ATF-4 for the power steering unit?
Это хороший вопрос?
Это хороший вопрос?
Check the cap of the power steering fluid reservoir or possibly the side of the power steering fluid reservoir. There will probably be a sticker or raised/engraved letters indicating what fluid to use. Also, you can check the user manual-the fluid spec will definitely be in there.
Был ли этот ответ полезен?
yes to Andrew, or call any dodge dealer. The oem spec is best if you want longevity, but if your penny pinching, and its a beater the ATF is fine. they are essentially the same, with slightly different additives.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 4,705
