A play oven that bakes real treats. Hasbro has sold 18 million of these little cookie factories. The secret ingredient is love!
5вопросов Показать все
Why won't my easy bake oven turn on?
My easy bake oven won't turn on? I plug it in and nothing. Waited over 20 minutes! Help!
Это хороший вопрос?
Оценка 1
Добавить комментарий
4 Ответов
Выбранное решение
How old is your easy bake? The older models used a light bulb to cook, and it needed replacing occasionally.
Был ли этот ответ полезен?
Оценка 3
6 Комментариев:
@avanteguarde Only one reputation point needed for tee shirt :-) @kaykay
из
Thanks for the head's up @mayer ! Nice work @avanteguarde :) Stoked to have you in the community. Shooting you an email now!
из
I bought a easy bake oven and it wont turn on i was told it needed a bulb but cant find any help to find out where it goes
из
Its the new modle
из
Trying to send picture
из
Показать 1 больше комментариев
picture of my modle oven
Оценка 1
check first your electric ranges it might be 240VAC, loose or burnt wire connection, defective thermostat because this monitors oven temperature. Hope it helps!
https://navalesgq.wixsite.com/freelancer
Оценка 1
1 Комментарий:
I contacted Hasbro, I think the circuit board of my Easy Bake Oven is done
из
The Easy Bake does require a 120 Volt adapter.
Оценка 0
Добавьте свой ответ
Erica будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 8
За последние 30 дней: 19
За всё время: 2,472
