Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
342вопросов Показать все
Where can I buy the LED backlight power cable
Where can I buy the LED backlight power cable ?
The one from step 6 in this article: iMac Intel 21.5" EMC 2389 Display Replacement. Cant find in anywhere no web.
Thanks
Это хороший вопрос?
Оценка 1
2 Комментариев
You are certain, or course, that the Display was you problem? Would hurt to ask.
из
yes the cable is damaged
из
Добавить комментарий
1 ответ
Выбранное решение
Sadly, the cable is not available as a separate part. Depending on what happened you may need to try to splice the cable back together or replace the complete display unit Ouch!
  • 21.5” LCD Panel - 661-5536
Here's the full listing of the display cables Apple offers as spares:
  • LCD V-Sync Cable - 922-9368
  • DisplayPort Cable - 922-9497
  • LCD Temp Sensor Cable - 922-9623
Был ли этот ответ полезен?
Оценка 3
2 Комментариев:
Is there way to find used LED backlight power cable of broken screen, in some online computer part store?
Thanks
из
Sadly, it's not something that they would salvage. It would take some hunting to find a recycler who might put one aside for you.
из
Добавьте свой ответ
Swiss будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 450
