The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
428вопросов Показать все
Can't find compatible chat headset
cannot find a chat headset compatible with the xbox one s.
purchased three different headsets which were all meant to be compatible but none are working on the one s.
i even had the console replaced incase it was the problem.
the headsets are all working on friends xbox one but not on the one s. please help x
Это хороший вопрос?
Оценка 0
Добавить комментарий
3 Ответов
Выбранное решение
Funny story, the headset that came with PS4 actually works. I have been using it for some time.
It is likely that the iphone earpods will work as well but mine are Chinese spec, which have the mic pin reversed. I can't get the chat and stereo sound to work at the same time. Dunno if the US spec ones will work.
Был ли этот ответ полезен?
Оценка 2
You need to find a headset that has a plug on your controler ( at the bottom ) and conect it, i may be wrong but give it a shot
Оценка 1
Make sure you use a Xbox one controller with a headphone jack. Some of the earlier ones lack one.
Another weird thing. My sons beats did not work with the cord they came with but had an extra V-moda Crossfade 2 cord with mic and it worked perfectly.
Also my V-Moda Crossfade 2 with the cords it came with works perfectly. Also the V-moda crossfades sound great for music etc.
Оценка 0
Добавьте свой ответ
geordierichardson будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 105
