The machine won't turn off. It goes through the cycle again
The machine won't turn off, when it is done spinning it immediately starts filling again and goes through the cycle again and again.
Это хороший вопрос?
Это хороший вопрос?
@barbeblom , Barb, sounds like a bad timer/control board allowing washer to keep cycling. Check the video below for more about a washer's timer function. You could try a google search using your make and model #. If not comfortable working on your appliance, have a good repair Tech. have a look, diagnose and estimate repair.Good luck.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 29
За всё время: 9,029
1 Комментарий
I have to manually stop the washing cycle and then put on spin cycle and manually stop it also. It won't go to the next cycle on its own.
из janetsillings90
