iPhone 6 won't charge.
the phone went dead. I changed the battery and the phone turned on. but will not charge. I've tried to change the battery twice but will not charge. What could be wrong?
Это хороший вопрос?
Это хороший вопрос?
if th phone powers on with a fully charged battery but will not charge the battery, I'd suspect that the lightning port flex needs replacing. Follow this guide to replace.
Был ли этот ответ полезен?
Or the charger port is clogged and needs to be cleaned out. With a toothpick or something equivalent.
Worst case scenario is that the U2 Tristar Charging IC has gone bad which usually happens with bad car chargers.
Hi
1.Check The Charging Dock Connector inserting the cable weather it is fully inserting inside or not if not Then just clean the dust inside of the connector then insert n Charge It Might Work
2.Either u need to change the Dock Connector
3.Try TO Restore the DEVICE
Hope It Works
Thanks
Varun
Thanks all for advice. I will soon get a new charging port in the mail. expects that it will fix the problem.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,015
