Why is the blade making unusual noise and stopping after a few seconds
Firstly where shud the spring ends be placed while reassembling the parts
And the trimmer is making unusual noise and stopping after a few seconds
Это хороший вопрос?
Это хороший вопрос?
Siddhant dhandhania , Make sure the head is clean and undamaged,try lubricating blade very lightly, ensure assembled correctly. If all looks good and still stopping after a very short time batteries could be worn out or motor may be on it's way out. If still under warranty use it for replacement/repair/refund. Use the link below to aid in blade installation. Good luck.
Был ли этот ответ полезен?
i get this on mine, its usually Jammed. i lucked out and baught a water proof model. so i just run it under the tap, and its good to go. i know this probably doesnt help, but its better to try before replacing it.
I have just replaced the new set of blades. After some initial 5-6 shaves, this problem has started. Even after cleaning the three rotors under fast tap, the problem refuses to go. Can you suggest some other solution please?
try cleaning it and then add some oil inbetween the blades if you havent done that yet
За последние 24часов: 1
За последние 7 дней: 12
За последние 30 дней: 40
За всё время: 6,267
