Got new battery for lg vk810 let it go dead
I got a new battery for lg 8.3 vk810 accidentally I let it completely die now I can't get it to charge or turn on I tried the 20second thing but it still won't do. anything. Also my screen is very dim?
Это хороший вопрос?
5 Комментариев
lisasaunders528 "still won't do. anything. Also my screen is very dim?" so it does come on but has a very dim screen? Clarify this for us. A dead battery would not give you anything.
из oldturkey03
I replaced the battery and was working fine for a couple of days but then accidentally. Let it die now I can get it to charge or turn on
из lisasaunders528
Sounds like you are having an issue with either your charging cable, your charger, or the charging port. Have you tried a different charger/cable?
из oldturkey03
Yes I've tried different cable and charger box it will sometimes show me the LG screen but can't get it to go past that I just ordered a new charger Port with flex cable so I hope it's the problem.
из lisasaunders528
Also every once in a while I get a faded ring around the outside of the screen does that have anything to do with it or is that a hole new problem itself?
из lisasaunders528
