dropped my galaxy s7 phone and the phone screen is bleeding purple.
I dropped my Samsung Galaxy S7 phone, screen did not break, however it was purple on the top and know it has bleed thru more. Do I have to have the LCD replace?
Это хороший вопрос?
Это хороший вопрос?
I assume by "bleeding purple" it's looks more like cloudy blobs of purple rather than purple lines. I would say that this is a bad LCD and needs to be replaced if that's the case. If it is lines then surely it is possible as Gigabit said for the LCD connector to have been knocked loose if it isn't due to physical damage to the LCD itself that is visible.
Был ли этот ответ полезен?
hi, my screen is fully covered in purple apart from the time section. i really need to use it though so i can clone my phone before leaving overseas....could you help me by informing me how to remove my screen and get the ink away.
I want to know if my screen is cracked can color leak out
Actually friend you have broke your screen it is LC crystal in LCD who have to replace the LCD
Hello, my phone is also bleeding the purple stuff. And there is also a few colored lines that have appeared recently. Do you know how to fix this? I have no idea how to take the phone apart and don't know anything about phones.
I spilled sanitizer on it and now its the same it works fine but the purple stuff gets darker and bigger over time i gotta new phone but just to lef y all know that dont use sanitizers on your phones i dropped it it didnt happen it happened
after i wiped it with sanitizer my screen was a little bit cracked so yeah now th phone is slowly dying as the purple stuff takes up the entire screen do yeah see ya later and try to remember if you used sanitizer on your phone cos thats how it happened to mine
Hi @ Delta Stegeman,
Here’s a link to the ifixit Samsung Galaxy S7 guides.
They should be of some help in showing how to replace the screen.
My phone dropped and the ink started spilling what measures can I take inoder for it not to spill any further because it is presently also intend to use the phone for a very long time say in the next 3 months to come and more
Hi @ Mary Ariyo,
It is only going to get worse and there's not much that you can do about it except to replace the screen.
I suggest that you backup the phone to the cloud or a PC using the phone's backup feature while you still can so that you have a copy of your personal data, before the screen fails entirely and you cannot use the phone at all
If the LCD is broken, or there is little spot on the screen. The spot will get bigger over time. So, you need a new screen in the end.
My problem phone would not charge as if the port was not accepting the current..bought a fast charger layer bit flat half hour later 30% charge but a blue purple blob like a ink spill appeared not the compkete screen is covered.,why?
Black scratchy blob all over the screen behind is blue I th small portions of the normal screen
Would removing t
He battery stop this flow .
Can you still see the screen on the top? Is it like a big blob of purple? Or lines? Try to re-seat the LCD connector, might have been knocked loose.
How would you do that?
you need a new screen, screen got damaged when you dropped
Hi @jephiano,
It's not going to get better by itself.
The phone needs to be opened and looked at to determine what the cause is, either a loose connection or a faulty screen which will need to be replaced.
Check my answer above for more information on how to open the phone etc..
Hi @XoX Denisa XoX
Here’s a link to the ifixit Samsung Galaxy S7 Screen Replacement guide.
You may notice that the repair is rated as difficult.
If you’ve never done a phone LCD screen replacement before this is not a good model to try as a first attempt.
Contact a reputable., professional mobile phone repair service and ask for a quote to replace the screen. It may be cheaper in the long run
No other way than to replace the whole display
За последние 24 часов: 3
За последние 7 дней: 24
За последние 30 дней: 91
За всё время: 212,386
20 Комментариев
Broken LCD would recommend replacing the full display unit.
из Skiller
i have the same thing and i have Samsung galaxy s7 pro ... how u sovle it ?
из Nada Sameh
Same happening right now on my moto
из atmosphere yt
The same thing is happening to my phone and the lower half of my screen is completely black
из Unicorn weirdo
I have a small bleed on the scree( scratch inside the scree), this is very tiny scratch but still is there any alternate for this to resolve. please help if u guys have gone through this.
из aneel
Показать ещё 15 комментариев
