The GoPro Hero5 Black is an HD waterproof action camera released by GoPro in October of 2016. The 4k resolution video camera has voice control, a touch screen display, and built in WiFi.
85вопросов Показать все
The LCD screen has a hairline fracture
I purchased my GoPro about a month ago - and the GoPro Hero LCD screen has a hairline fracture! I just took it out the case after using it - and the crack appeared. I did not drop of doing anything that would impact the camera. Has anyone else had this issue? and or know how to repair it or warranty the camera?
Это хороший вопрос?
Оценка 2
1 Комментарий
Is it still waterproof
из
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Are you sure it's cracked? And is everything on the LCD still visible?
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
100% cracked. LCD still works fine
из
@jezza even if it is cracked, if it is visible I wouldn't worry about it. But if it develops black spots then replace it. Even if you replace it it would probably still be pretty expensive as the device is still new.
из
Where could i go to get it replaced?
Оценка 0
I noticed mine was cracked this evening too. Hasn't been dropped or abused in any way. I think this is a protective glass over the LCD screen, since the LCD screen still seems to work fine.
Would be interested know how I go about getting it fixed.
Оценка 0
Добавьте свой ответ
Jezza будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 8
За всё время: 4,257
