in my acer after installing windows 10 my touchpad is not working?
my acer aspire E 15 es1-512-c3x9 after installing windows 10 enterprise the touch stop working, and i don't even see the driver of my touch pad even after installing them, and when i try to change the the bios setting from legacy to uefi it say not bot file then i change to legacy and it boot yet touch pad not working how to fix please help .
thanks .
Это хороший вопрос?
23 Комментариев
Hi,
Have you checked if the touchpad is listed under either Mice and Other Pointing Devices or just Other Devices in Device Manager? See if there is a listing for a USB touchpad controller.
из jayeff
Hi, Acer machines often have a key that turns off the touchpad. It is often a function key (Fn) and is often on the F7 key but could be anywhere. The symbol looks like a hand on a square with a small circle and diagonal. Make sure your touchpad is not turned off. The key is pressed once (along with the Fn key) to turn on and again to turn off.
из Paul Ingarfield
I tried many times to use (fn) with f7 but still not working don't know whether I'm doing it wrong What must I do help me plz.
из Zizipho Madikazi
I use the pointer to access driver manager so it it's not functioning I cannot do that. No pointer= no browser, no file explorer, no nothing. It highlights but no action. And no hand on a square w/small circle and diagonal (is it the F8?) And how would I know if the touchpad is on or off? It's an ELAN pointer
из Barbara Danfordhirsch
Hi @ Barbara Dandfordhirsch,
Connect a USB mouse to the laptop and use it to navigate through to Device Manager etc etc
из jayeff
Показать 18 больше комментариев
