Comprehensive guides and support for a wide range of wearables including the Apple Watch, Android Wear powered watches, Fitbits, and more.
3229вопросов Показать все
My smart watch not chargin
MY smartwatch not charging,Bingo Smart watch U8
Это хороший вопрос?
Оценка 6
20 Комментариев
Do not charge this or even try to stick in the paper in the back if it's not charging . The bfirst thing you should do is take the back off carefully and mindfully. I have one brand new in box same issue took the back off come to find out there's a swollen battery almost ready to explode these things can hit up to 1000 degrees Fahrenheit and when exposed to oxygen can explode or catch fire. And you can't just take the battery out of some of them because it is soldered in by the negative and positive wiresI hate to see anyone get hurt over a cheap $15 watch. I have been nothing but complaints online about these watches I'm surprised there hasn't been a lawsuit and Recall yet Be mindful of your electronics with Lithium-ion batteries and do not charge if you see any signs of swelling.
из
If I Charge My Smartwatch DZ09 it won't Charge but it turn on
How Do I Fix This?
из
Hello, have you fixed yours? I have a similar issue with my brand new wristband as well. When I’m plugging it into the charger or computer it turns on and saying its charging bur when I unplug it after a while its not turning on
из
I bought 1 A6 Smart Bracelet and will charge then a blue screen but could not turn it on so over trying to charge it is magnetic
из
Meant it won't charge
из
Показать 15 больше комментариев
Добавить комментарий
2 Ответов
Выбранное решение
Have you pushed the reset button on the back with a pin ? Try charging it from a computer rather that a charger it may take longer but sometimes helps . If you still have no joy this may help
https://www.youtube.com/watch?v=yoboZuNy...
Был ли этот ответ полезен?
Оценка 2
13 Комментариев:
Be careful if it's taking a paperclip in to reset. I have one brand new in box having same issue took the back off and has a swollen battery and if you pierce these things and oxygen hits them they can possibly explode
из
I smart watch is not charging celebrando 07 smart warch
из
I can not see a reset button
из
my 113/D16 fitpro is not charging,pls what should I do?
из
My fitro charging point is not working, what can I do, please help
из
Показать 8 больше комментариев
我2023年2月在temu买了Model Y13的运动手表,戴了4个月就充不进电不能开机了。7月我又买了一个同样型号的,只是充电器样式不同,以为是技术有所提高,结果只用了两个星期就发生同样的问题充不了电了。希望厂家能给予解决方案。
Оценка 0
Добавьте свой ответ
Abhijit Sen будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 11
За последние 7 дней: 67
За последние 30 дней: 216
За всё время: 105,654
