Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
429вопросов Показать все
Wont turn on. Diagnostic led no light
iMac does not power ON
Hi,
I have a Power issue with my mid 2011 iMac.
I've already opened it up. I have experience with repairing electronics, etc. But now i'm stuck. On the logic board ( Main board) :
Diagnostic LEd no light, I measure 12v and 5v on the supply.
Это хороший вопрос?
Оценка 4
2 Комментариев
@djdanny what is the exact model of your iMac? Which one of the LED's is not coming on? what else have you checked? The more information you give the greater the chance of getting valid answers
из
Imac 2011 mid 21,5" i5 quad core
No status led light on motherboard.
I check power cord and psu 12v and 5v
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
@djdanny if you have no LED light up you are having problems with the PSU. You said you tested it for 12V and 5V but are not telling us where and how you tested this. At this point I would consider starting by replacing the power supply and/or double check your connections etc.
Был ли этот ответ полезен?
Оценка 1
I have the same issue, I only have led 1 and when i press the power button - led 1 shuts off. There is a little fan spin for a millisecond.
Оценка 0
Добавьте свой ответ
Djdanny будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 495
