Can I put a single cab transmission into a extra cab truck?
both trucks are 94 rangers both have same motor is the transmission going to match up with the driveline or will i need the driveline off single cab?
Это хороший вопрос?
Это хороший вопрос?
94 and 95 had Two transmissions for this truck A4LD which was with an overdrive and a 4R44E which was used till 2000 They both will work for you but you do need to measure the tail stock . As long as the tail stock are the same length then you wont have a problem.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 175
