The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
418вопросов Показать все
xbox one storage/hard drive enquiry
Hi! New to xbox soon. Do you need a laptop/pc when changing storage/ hard drive on xbox one like you do with ps4?
Это хороший вопрос?
Оценка 0
4 Комментариев
Justin G, thanks for taking the time to answer my query. Also, for all the information you gave. Much appreciated!
из
It's what I love to do! Is it the Xbox one S or just the one? Feel free to contact me when you get Xbox live and maybe we can join up on there!
из
Are you talking about internal or external? If it's an internal your talking about the below answer doesn't work.
из
Justin G. Xbox one s - FIFA 17 1T
из
Добавить комментарий
1 ответ
Выбранное решение
No, the xbox will format the hard drive itself.
Scroll left from Home to open the guide.
Select Settings.
Select All settings.
Select System.
Select Storage.
Select Manage storage. If you see your storage device listed, your console has detected it.
If your Xbox doesn't recognize this right away..
Select Settings.
Select System.
Look under Console info & updates. If it says Update available, there’s an update you need to install.
After you’re done installing the update, go back to Settings and select System, and then Storage. See if your device appears in the list.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
john paul будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 102
