Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
429вопросов Показать все
I have trouble after 3 hours the mouse and bluetooth stop
iMac 21.5" Mid 2011 2.5 GHz Intel Core i5
Hello,
I'm having trouble with my 21.5" iMac. After working for 2 - 3 hours the mouse with Bluetooth and USB port connected keyboard stop working.
Sometimes I can work a whole day without any problems, other times it stops and I have to restart my system to get it working again.
How can fix this? Thanks
Update (02/26/2017)
I have this error: 4SNS/1/40000000: TH00-9.000
Это хороший вопрос?
Оценка 3
5 Комментариев
Have you tried running any diagnostics? How about rebooting your system and holding the 'Option' & 'D' keys to let the builtin diagnostics run
Reference: Startup key combinations for Mac
из
thanks friend
i will do and see what see
thanks
из
thanks so match
из
Can you please help, I have this model and my Bluetooth and key board is not responding.
из
have truble in ice
из
Добавить комментарий
1 ответ
Выбранное решение
Someone put in a replacement HD and forgot to add in the needed hardware sensor if they put in a non-Apple drive the system came with. Here is the needed sensor: OWC In-line Digital Thermal Sensor for iMac 2011 Hard Drive Upgrade and here is the needed steps to get to it: iMac Intel 21.5" EMC 2428 Hard Drive Replacement. You can stop as Step12 to slide on the sensor for the drive you have now.
Был ли этот ответ полезен?
Оценка 3
Добавьте свой ответ
abdulkafi будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 595
