The Acer Chromebook C710-2847 is part of Acer's line of low-price netbooks running Google's Chrome OS. The devices are simply constructed needing just one screwdriver to take them apart.
Laptop fell apart- How to repair?
My laptop's casing around the screen and base of the laptop is starting to come apart. I am wondering if there is any easy way to fix it- besides duct-taping the entire thing- which is probably a bad idea!
Here are some pictures of the current issue.
Part of the piece in the back that helps the laptop close/open has broken off.
I am also unable to close the laptop.
is there anything I can do to fix this?
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
@solarixsy , Solarisxsy , That really is in rough shape. I think your best bet would be to try and find a good used parts machine on Ebay, Amazon,Craig list, etc., and transferring parts to fix. Duct tape is not a perfect idea, looks like some one already was doing this and it might hold it together until you find replacement parts. Find below a couple disassembly guides that may help when you get some replacement parts. Good luck.
Acer Chromebook C710-2847 Screen Replacement
Acer Chromebook C710-2847 Hard Drive Replacement
Acer Chromebook C710 Hard Drive Изображение
Инструкция
Сложность:
Средне
3 - 5 minutes
Acer Chromebook C710 Screen Изображение
Инструкция
Сложность:
Средне
20 minutes
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Solarisxsy будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 7
За всё время: 485
