The HP Deskjet Ink Advantage 1515 is an all-in-one desktop inkjet printer/scanner by HP. Model number B2L57A#AKY.
6вопросов Показать все
Why the printer won't print
I tried printing but the paper just came out blank. Why?
Это хороший вопрос?
Оценка 2
4 Комментариев
I just replace the ink but can't print because the printer doesn't seem to grab the paper, the paper just went in half way and nothing was print on it.
из
Hi @ adnan abdul ajis,
If you have the HP 1515 can you copy or scan a document OK using the printer's control panel?
If it works OK this way, can you try a test print from the computer that the printer is connected to? (usually found in the Printer properties area in the computer)
из
hey my printer hp 1515 just wont print . i press print from my laptop and nothing happens
из
hey my printer error, it can scan but its cant prin, and i can open the properties..
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
No ink maybe? Lol does the rail for the ink cartridges move? Or does it simply spit the paper out
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Leolando Nable будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 9
За всё время: 3,230
