lenovo MIIX 700 and it doesnt boot
I have a lenovo MIIX 700 and it doesnt boot I tried it all and I cant find a reset hole to stick a clip in . I need help
Это хороший вопрос?
Это хороший вопрос?
Hi,
Does the tablet indicate that it is charging when you connect the charger to it?
When you say that you tried it all, did you try to reset the tablet using the Volume Up and the Power button to get into the recovery menu? If so what happened?
Here is the procedure:
Shut down the computer and wait at least five seconds.
Press and hold the Volume Up button and then press and hold the Power button, (both buttons are now held together) until the Novo Menu appears on the screen.
Novo menu > System Recovery > Troubleshoot > Reset this PC
Here is an image taken from the user guide that shows the options available in the Recovery menu. Be aware of which option you choose in the Reset menu as you could lose all your data if you choose Remove Everything and restore the tablet to its' factory default condition. Select Keep my files as highlighted in the image.
(click on image to enlarge for better viewing)
Был ли этот ответ полезен?
Tried this but no Novo has come up. No sure what else to try
За последние 24 час(ов): 0
За последние 7 дней: 6
За последние 30 дней: 20
За всё время: 8,431
1 Комментарий
Hello. I have quite same problem, after updating the bios, it crashed, so first I could go to the bios so I did to check settings, and now it continually reboot on the Lenovo logo... Can you help me please? Or is my motherboard dead?
из Cyril Weissler
