What dose f:01 mean
when the washer start it stop and f:01 comes up
Это хороший вопрос?
It is an error code for a bad control board
Look at this link for tips to repair it: http://www.f1error.info/repair_whirlpool...
Был ли этот ответ полезен?
Posts on here refered me to an air hose near the control board. Check for it being crimped, you can blow through it and make sure you hear air coming into the drum. This can be your issue not your board, people have bought boards and still had this problem. So check the hose first. F1 is referring to pressure not being right on the water from air flowing against a sensor via this tube.
As previously mentioned, F.01 can either be:
1) control board and/or
2) air tube that plugs into control board
You need to check the tube is clear, not kinked or if your control board works.
You should run the diagnostic on your make/model which will cycle through all the water intake steps C0 through C7 which will test the function of said tube as well.
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 11
За всё время: 3,519
Any updates?
из Tim D
start as the machine starts counting down lid locks and f001 comes up
из jeffjefm
