ssd可以更换吗?
ssd存储有点小了,我想换个大一点的,是否可以更换?
Can SSD be replaced?
My SSD storage is a bit small, I would like to change a little bigger drive, can be replaced?
Это хороший вопрос?
Это хороший вопрос?
请参考 iFixit 指南 (Please review this iFixit guide): MacBook Air 13" Early 2014 Solid-State Drive Replacement
Был ли этот ответ полезен?
您的新SSD驱动器的选择是找到一个Apple SSD或使用其中一个第三方:
Your choices for new SSD drive is locating an Apple SSD or using one of these third parties:
Macbook Air的SSD可以非常轻松的更换,操作步骤非常简单。但是SSD的价格是非常贵的。128G二手都能到¥600
在靠谱的地方购买到以后,使用⭐️1.2螺丝刀打开背板10颗螺丝,T5螺丝刀拧下SSD上一颗螺丝,即可更换,详细请参照上方的拆解指南
Macbook Air's SSD can be very easy to replace, the operation steps are very simple. But the price of SSD is very expensive. 128G second hand can go to ¥ 600
After you buy it in a reliable place, use ⭐️1.2 screwdriver to open the backplane 10 screws, T5 screwdriver to remove the SSD on a screw, you can replace, please refer to the above disassembly guide
要知道你的ssd是什么接口的,然后买对应的接口的ssd就可以了
To know what your SSD interface, and then buy the corresponding interface SSD on it
可以换,关键apple的固态太贵了。cf卡也可以升级
Can be changed, the key apple's solid state is too expensive. cf card can also be upgraded
肯定是可以换的,不过买这些东西基本都在华强北可以找到
It must be changeable, but these things are basically found in Huaqiang North.
可以的,买一块m2接口的固态硬盘就行,再去淘宝买一个转接卡(m2接口转苹果接口)。完美运行
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 1,593
